After the 2356 error appears the packages are not reinstalled/installed correctly (files not replaced).
Please advise.
Posted 31 October 2001 - 15:49
Please advise.
Posted 01 November 2001 - 15:07
If you try to install from the cached package using for example add/remove programs. Your install must fail because the files are no longer present.
If you are reinstalling with the original package then you may be able to re-install adding the v option to REINSTALLMODE.
