I have an installer made that has a buch of DLLs included. These DLL's get copied to the system32 folder <WINSYSDIR> when the application installs. When I install my application on one computer it works fine, when I install it on another computer the DLL files will not copy into the system32 folder. I have administrator rights on both machines. Has anyone encountered this before? Do you have any suggestion on how to fix this? I assume its a problem with the computer and not my Installer. Any suggestions would be greatly appricated.
DLL files not installing
Barlow
, Mar 30 2005 16:39
Posted 12 April 2005 - 14:03
for debugging, try to add abreak point before and after the file transfer, now try to register the dlls manually with the regsvr32, most probably you will fail and the message from the regsvr32 can help you determine the problem.
Posted 12 April 2005 - 15:53
sorry, what IS version do you use?
in http://forum.install...showtopic=12286 you asked the same question ...
Gruß / regards
Thomas
Thomas
Posted 26 April 2005 - 12:47
Yeah, I realized too late that I posted this in the wrong forum. We are using version 5.5.
