Hey everyone,
I am attempting to run an InstallShield Wizard silently. I have created a silent install response file. It appears to be recording everything except 1 entry. Looking at the response file and researching, i can't figure out how to make the InstallShield prompt to NOT popup and just either accept the default (since this window that pops up has only 1 entry that you can choose and then you hit next) or record my response as 'next' inside the response file.
Here are my command line parameters:
record mode: setup.exe /r /f1"C:\temp\setup.iss"
silent install: setup.exe /s /f1:C:\temp\setup.iss"
response file:
[InstallShield Silent]
Version=v7.00
File=Response File
[File Transfer]
OverwrittenReadOnly=NoToAll
[{94EF8121-5660-4A28-8734-5F03FC6517B2}-DlgOrder]
Dlg0={94EF8121-5660-4A28-8734-5F03FC6517B2}-SdWelcome-0
Count=6
Dlg1={94EF8121-5660-4A28-8734-5F03FC6517B2}-SdLicense2Rtf-0
Dlg2={94EF8121-5660-4A28-8734-5F03FC6517B2}-Display Destination Location-0
Dlg3={94EF8121-5660-4A28-8734-5F03FC6517B2}-SdStartCopy2-0
Dlg4={94EF8121-5660-4A28-8734-5F03FC6517B2}-MessageBox-0
Dlg{94EF8121-5660-4A28-8734-5F03FC6517B2}-SdFinish-0
[{94EF8121-5660-4A28-8734-5F03FC6517B2}-SdWelcome-0]
Result=1
[{94EF8121-5660-4A28-8734-5F03FC6517B2}-SdLicense2Rtf-0]
Result=1
[{94EF8121-5660-4A28-8734-5F03FC6517B2}-Display Destination Location-0]
Result=1
szPath=C:\Brentwood
[{94EF8121-5660-4A28-8734-5F03FC6517B2}-SdStartCopy2-0]
Result=1
[Application]
Name=Midmark IQmanager 8.5.0
Version=8.5.0
Company=Midmark Diagnostics Group
Lang=0409
[{94EF8121-5660-4A28-8734-5F03FC6517B2}-MessageBox-0]
Result=1
[{94EF8121-5660-4A28-8734-5F03FC6517B2}-SdFinish-0]
Result=1
bOpt1=0
bOpt2=0
[{3B1FCF44-F864-485C-94B6-0D1644C49821}-DlgOrder]
Count=0
[{04F1FC14-9D6D-4553-9DFC-F285EC1EFBCC}-DlgOrder]
Count=0
The "display destination location" section is the part directly after the popup screen. so it appears that its not recording an entry here.
1. How do i get this piece of the install to record properly in the response file?
2. Can i get it to accept the default and move on without popping up?
3. Can i customize the response file, and if so, what is the exact line entry going to be called?
