Hi Glytzhkof,
Please find my log file for this.
=== Verbose logging started: 4/8/2014 18:34:47 Build type: SHIP UNICODE 5.00.7601.00 Calling process: C:\PROGRA~1\COMMON~1\INSTAL~1\Driver\7\INTEL3~1\IDriver.exe ===
MSI © (C4:A8) [18:34:47:223]: SOFTWARE RESTRICTION POLICY: Verifying package --> 'C:\Users\taakash\AppData\Local\Temp\_is9C0\FTP Server.msi' against software restriction policy
MSI © (C4:A8) [18:34:47:223]: Note: 1: 2262 2: DigitalSignature 3: -2147287038
MSI © (C4:A8) [18:34:47:223]: SOFTWARE RESTRICTION POLICY: C:\Users\taakash\AppData\Local\Temp\_is9C0\FTP Server.msi is not digitally signed
MSI © (C4:A8) [18:34:47:231]: SOFTWARE RESTRICTION POLICY: C:\Users\taakash\AppData\Local\Temp\_is9C0\FTP Server.msi is permitted to run at the 'unrestricted' authorization level.
MSI © (C4:A8) [18:34:47:233]: Cloaking enabled.
MSI © (C4:A8) [18:34:47:233]: Attempting to enable all disabled privileges before calling Install on Server
MSI © (C4:A8) [18:34:47:236]: End dialog not enabled
MSI © (C4:A8) [18:34:47:236]: Original package ==> C:\Users\taakash\AppData\Local\Temp\_is9C0\FTP Server.msi
MSI © (C4:A8) [18:34:47:236]: Package we're running from ==> C:\Users\taakash\AppData\Local\Temp\_is9C0\FTP Server.msi
MSI © (C4:A8) [18:34:47:238]: Machine policy value 'DisableUserInstalls' is 0
MSI © (C4:A8) [18:34:47:238]: APPCOMPAT: Uninstall Flags override found.
MSI © (C4:A8) [18:34:47:238]: APPCOMPAT: Uninstall VersionNT override found.
MSI © (C4:A8) [18:34:47:238]: APPCOMPAT: Uninstall ServicePackLevel override found.
MSI © (C4:A8) [18:34:47:238]: APPCOMPAT: looking for appcompat database entry with ProductCode '{619E3260-203D-4858-9968-555C64E65377}'.
MSI © (C4:A8) [18:34:47:239]: APPCOMPAT: no matching ProductCode found in database.
MSI © (C4:A8) [18:34:47:250]: MSCOREE not loaded loading copy from system32
MSI © (C4:A8) [18:34:47:256]: Note: 1: 2262 2: MsiFileHash 3: -2147287038
MSI © (C4:A8) [18:34:47:256]: Machine policy value 'DisablePatch' is 0
MSI © (C4:A8) [18:34:47:256]: Machine policy value 'AllowLockdownPatch' is 0
MSI © (C4:A8) [18:34:47:256]: Machine policy value 'DisableLUAPatching' is 0
MSI © (C4:A8) [18:34:47:256]: Machine policy value 'DisableFlyWeightPatching' is 0
MSI © (C4:A8) [18:34:47:256]: Enabling baseline caching for this transaction since all active patches are MSI 3.0 style MSPs or at least one MSI 3.0 minor update patch is active
MSI © (C4:A8) [18:34:47:257]: APPCOMPAT: looking for appcompat database entry with ProductCode '{619E3260-203D-4858-9968-555C64E65377}'.
MSI © (C4:A8) [18:34:47:257]: APPCOMPAT: no matching ProductCode found in database.
MSI © (C4:A8) [18:34:47:257]: Transforms are not secure.
MSI © (C4:A8) [18:34:47:257]: Note: 1: 2262 2: Control 3: -2147287038
MSI © (C4:A8) [18:34:47:257]: PROPERTY CHANGE: Adding MsiLogFileLocation property. Its value is 'C:\Users\taakash\AppData\Local\Temp\MSI31d2f.LOG'.
MSI © (C4:A8) [18:34:47:257]: No Command Line.
MSI © (C4:A8) [18:34:47:257]: PROPERTY CHANGE: Adding PackageCode property. Its value is '{91ED91CD-C57F-471F-9798-54605ED68CA4}'.
MSI © (C4:A8) [18:34:47:257]: Product Code passed to Engine.Initialize: '(none)'
MSI © (C4:A8) [18:34:47:257]: Product Code from property table before transforms: '{619E3260-203D-4858-9968-555C64E65377}'
MSI © (C4:A8) [18:34:47:257]: Product Code from property table after transforms: '{619E3260-203D-4858-9968-555C64E65377}'
MSI © (C4:A8) [18:34:47:257]: Product registered: entering maintenance mode
MSI © (C4:A8) [18:34:47:257]: Determined that existing product (either this product or the product being upgraded with a patch) is installed per-machine.
MSI © (C4:A8) [18:34:47:257]: PROPERTY CHANGE: Adding ALLUSERS property. Its value is '1'.
MSI © (C4:A8) [18:34:47:257]: PROPERTY CHANGE: Adding ProductState property. Its value is '5'.
MSI © (C4:A8) [18:34:47:257]: PROPERTY CHANGE: Adding ProductToBeRegistered property. Its value is '1'.
MSI © (C4:A8) [18:34:47:257]: Entering CMsiConfigurationManager::SetLastUsedSource.
MSI © (C4:A8) [18:34:47:257]: Specifed source is not already in a list.
MSI © (C4:A8) [18:34:47:257]: User policy value 'SearchOrder' is 'nmu'
MSI © (C4:A8) [18:34:47:257]: Machine policy value 'DisableBrowse' is 0
MSI © (C4:A8) [18:34:47:257]: Machine policy value 'AllowLockdownBrowse' is 1
MSI © (C4:A8) [18:34:47:257]: Adding new sources is allowed.
MSI © (C4:A8) [18:34:47:257]: PROPERTY CHANGE: Adding PackagecodeChanging property. Its value is '1'.
Another version of this product is already installed. Installation of this version cannot continue. To configure or remove the existing version of this product, use Add/Remove Programs on the Control Panel.
MSI © (C4:A8) [18:34:47:302]: Note: 1: 1729
MSI © (C4:A8) [18:34:47:302]: Product: FTP Server -- Configuration failed.
MSI © (C4:A8) [18:34:47:304]: Windows Installer reconfigured the product. Product Name: FTP Server. Product Version: 1.2. Product Language: 1033. Manufacturer: XYZ Reconfiguration success or error status: 1638.
=== Verbose logging stopped: 4/8/2014 18:34:47 ===
Thanks and Regards,
Aakash
Edited by aakash.tiwari12@gmail.com, 08 April 2014 - 14:11.
