Can anyone advise the best way to detect if an instance of SQLServer2000 (or MSDE 2000) is installed on the client, and then decide whether a sub-feature (MSDE merge-module based installation) is then to proceed or not?
Thanks in advance.
Posted 12 June 2001 - 17:30
Thanks in advance.
Posted 21 June 2001 - 18:47
Posted 21 June 2001 - 20:08
using Power Editor in the table RegLocator I have the following values:
Signature_ (S72): SqlPath
Root(I2): 2
Key (S255): SOFTWARE\Microsoft\MSSQLServer\MSSQLServer
Name (S255): FullTextDefaultPath
Type (I2): 0
And then in the AppSearch table also in the Power Editor I have the following values:
Property (s72): SQLINSTALLPATH
Signature_ (S72): SqlPath (this is from other table)
If the registery key which is the install path for SQL 2000 is on the local system the value of that key will be assigned to the Property SQLINSTALLPATH then you can do a condition check to see if the property length is greater than zero or use the actual install path for something.
I hope this helps.
TDG
Posted 21 June 2001 - 20:31
I have gone a slightly different route - I am using :
key = SOFTWARE\Microsoft\Microsoft SQL Server
name = InstalledInstances
and AppSearch then puts that value in a property called SQLCURRENTINSTANCES.
How, then, can I evaluate that property to conditionally install my MSDE feature, or not?
Thanks in advance,
Posted 21 June 2001 - 20:50
SQLCURRENTINSTANCES NOT ""
basically as long as the property is not blank install this feature.
TDG
