To do this I have to set a value Should it be 0 or c:\ ?
If I add _BrowseProperty in property manager is it required to edit Directory table
using Direct Editor. What should be the values for Directory_Parent and Default Dir for directory _BrowseProperty
2. I want to know what is name of the property that will browse only the drive available is it ROOTDIR?
3. Is there any event that will create the foldername in a said directory if the foder does not exist .
Edited by sanjoygr, 30 March 2006 - 12:51.
