Does anyone know how to get logs of uninstall process happening when I uninstall something from ARP (Add/Remove Programs)?
Saurabh
Posted 17 June 2016 - 06:05
Saurabh
Posted 22 June 2016 - 21:02
Are you using InstallAnywhere? Maybe you can add a command line switch to the uninstall command in registry?
Posted 23 June 2016 - 05:15
No, sir.
I am using InstallShield 2014 Premier version.
How can I generate logs for this?
Posted 25 June 2016 - 09:00
Which project type are you using? So I can move your question to the correct forum
Posted 11 July 2016 - 15:24
I've moved the question to the Basic MSI section of the forum.
Did you try the information which is linked in my signature: HOWTO: Logging an MSI installation http://www.msifaq.com/a/1022.htm
Posted 13 July 2016 - 03:56
The link you mentioned tells about how to get logs while installation.
I want to know how can I get logs of uninstall process whenever I uninstall my application from Control Panel -> Add/Remove Programs.
Posted 14 July 2016 - 14:06
Oh, sorry that wasn'r clear in the document. The "Globally for all setups on a machine" section applies to all msi operations, including uninstall and repair operations. The MsiLogging property (which can be set via the General Settings of your project in InstallShield) should also apply to uninstall operations (if I recall correctly).
