I am facing a typical problem with Professional 7.
Details:
1. I have an application for which i developed and maintain the installer (say rev # 5.X).
2. I have to upgrade to a higher version rev # 6.X.
3. If older application, 5.X, is installed and is running, if i try to remove the application, it asks for a reboot because file are in use.
4. Now that i am going for a new version,6.X, i have to un-install the previous version,5.X (which requires a reboot because file are in use), and after reboot continue installing 6.X.
5. One more problem, if i lauch the un-installation for 5.X using "UninstallApplication" function, it shows the maintenance options, "modify","repair" and "un-install". So "UninstallApplication" is not the option.
I need:
1. Suggestion on how to remove the older version. I have seen Apple - iTunes software which remove the earlier version completely and install the new one, and guess what, this is done with Professional.
2. A better way of how to solve the problem if you have.
Thanks!
Mayur
