Posted 05 January 2009 - 08:02
I haven't checked this merge module, and it is a great initiative vrapp. However, be careful with new Microsoft files - they tend to be under OS protection and installed via other mechanisms than MSI. Microsoft Protected Files should never be installed at all, by any other means than Microsoft's own installers. The reason for this is that Microsoft (understandably) are the only ones with knowledge of the api's used to install protected system files. If your installer is kicked off with REINSTALLMODE = amus windows installer will try to force downgrade files. This can trigger nasty, mysterious runtime errors if a protected file is attempted downgraded.
Vista appears to have a new system of file protection that also covers parts of the registry. It is apparently called Windows Resource Protection (WRP) - that's all I know about it :-). On older windows version there should be a folder called "dllcache" in C:\windows\system32\dllcache or similar. It will contain a number of files that are protected. If you find the file here it is protected, but if you don't I think it still could be protected - the reason being that the dllcache folder size is controllable by policy as far as I know.
