Best Answer Stefan Krueger , 11 May 2016 - 19:52
Move your DoAction event up, so it gets executed before the NewDialog event
Go to the full postBest Answer Stefan Krueger , 11 May 2016 - 19:52
Go to the full postPosted 11 May 2016 - 14:01
I am using install sheild 2015 to create a setup. In my database credentials window, Database catalog is mandatory field for me. so i wrote a vb script custom action for next button to check if database catalog is empty or not to open the next window.
Now the problem is that I entered the catalog name and clicked on next button. it not navigating to next screen which is not correct.Then immediately again i clicked on next button where it is navigating to next screen. first time action is failing. Below is the vb script code which i used.
Edited by Bharani Reddy, 11 May 2016 - 14:04.
Posted 11 May 2016 - 19:52 Best Answer
Posted 12 May 2016 - 06:32
Hi Stefan,
Thanks a lot. It worked!!
As I am new to install shield I was not knowing that I can set the order of the doaction to perform.
Once I changed the order it worked properly.
