Best Answer deramor , 22 August 2013 - 20:25
Problem solved. =! does not mean the same thing as !=. Who knew?!
Go to the full post
Go to the full post
Posted 22 August 2013 - 18:51
Hello-
My company has written a service that grabs large chunks of memory (up to 1Gig) to use for data transfers. My installer needs to start this service and detect a failure to start. A failure to start indicates that memory is fragmented and the computer must be rebooted.
In order to alert the user to this failure condition I have done the following:
Created a public property CUSTOM_REBOOT and set it to 0.
Created a custom action running install script code. It is Immediate and scheduled after InstallFinalize.
This CA fires correctly since I can watch the system memory usage change.
In the code I have the following:
function Restart_MMS(hMSI)
NUMBER nvServiceState;
begin
ServiceStopService("MemoryService");
ServiceStartService("MemoryService","");
Delay(2);//wait for 2 seconds before looking at the service state.
// The MMS will enter the started state and wait for 1 second before closing if it can't get the
// required amount of RAM thus giving us a false reading
ServiceGetServiceState ("MemoryService", nvServiceState);
if(nvServiceState =! SERVICE_RUNNING) then //the service did not start. Need to reboot.
MsiSetProperty(hMSI, "CUSTOM_REBOOT", "1");
endif;
end;
Since the CA is outside of the InstallInitialize - InstallFinalize sequence, I assume I can access public properties directly without using CustomActionData.
I then modified ScheduleReboot built in CA (comes right after the one I wrote) to have the condition:
ISSCHEDULEREBOOT OR CUSTOM_REBOOT="1"
This condition is always false.
Am I doing something obviously wrong here? Am I testing for the value in the reboot condition correctly?
The behavior I expect would be if the CA detects the service is not SERVICE_RUNNING, It will set the property CUSTOM_REBOOT to 1. This will in turn trigger the reboot to get scheduled.
Any thoughts?
Posted 22 August 2013 - 20:25 Best Answer
