install condition issue (detecting office version)
Best Answer overlord , 19 March 2014 - 15:33
here is the log entry from a machine I have run the installer on:
Machine A:
AppSearch: Property: OFFICE_VERSION, Signature: NewSignature12
MSI (c) (48:F0) [10:12:13:847]: Note: 1: 2262 2: Signature 3: -2147287038
MSI (c) (48:F0) [10:12:13:847]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Office\11.0\Excel\InstallRoot 3: 2
Action ended 10:12:13: AppSearch. Return value 1.
MSI (c) (48:F0) [10:12:13:847]: Doing action: LaunchConditions
Action 10:12:13: LaunchConditions. Evaluating launch conditions
Action start 10:12:13: LaunchConditions.
Action ended 10:12:13: LaunchConditions. Return value 1.
MSI (c) (48:F0) [10:12:13:847]: Doing action: SetupInitialization
Note that the entry looks the same on Machine A and Machine B.
Machine A has office 2003 installed on it and the key is present.
Machine B has office 2010 and the key is not present.
Machine B:
MSI (c) (04:84) [10:20:46:095]: Note: 1: 2262 2: Signature 3: -2147287038
MSI (c) (04:84) [10:20:46:095]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Office\11.0\Excel\InstallRoot 3: 2
Action ended 10:20:46: AppSearch. Return value 1.
MSI (c) (04:84) [10:20:46:095]: Doing action: LaunchConditions
Action 10:20:46: LaunchConditions. Evaluating launch conditions
Action start 10:20:46: LaunchConditions.
Action ended 10:20:46: LaunchConditions. Return value 1.
MSI (c) (04:84) [10:20:46:095]: Doing action: SetupInitialization
I found this article  http://www.advancedi....php?f=2&t=9838
Which makes it sound like my problem is that I dont have both a 32bit and 64bit search. So I added another and I am testing it now. Will update with results shortly.
EDIT-- *** Yup that was it. I needed 2 system searches for this. Added to the condition to check for both 32 and 64bit and now it seems to work correctly***
Go to the full post
overlord
overlord
  • 38 posts
Posted 18 March 2014 - 20:02
Hey guys I'm back! I lost access to my old email account so I had to create a new user (formerly overlordchin).
Anyhow I am having trouble getting an install condition to work correctly. I added a system search for the following key:
HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\App Paths\excel.exe
and I am storing it in a property OFFICE_VERSION. After that I am using it in an install condition:
(Not OFFICE_VERSION="c:\Program Files\Microsoft Office\Office11\") AND(Not OFFICE_VERSION="c:\Program Files (x86)\Microsoft Office\Office11\")
which of course wont work if the main drive letter isn't c:\ or if it was installed to an alternate location.
is there a way I can tweak this to only look at the office11 part of the string?
Thanks in advance for any insight you guys have to offer.
overlord
overlord
  • 38 posts
Posted 18 March 2014 - 21:16
I tried changing it to look in
"HKLM\Software\Microsoft\Office\11.0\Excel\Installroot"
I then changed the install condition to:
(Not OFFICE_VERSION)
Which fails to properly detect the installation of that version of office even though the key is present at that location.
overlord
overlord
  • 38 posts
Posted 19 March 2014 - 15:33   Best Answer
Machine A:
Machine B:
Edited by overlord, 19 March 2014 - 16:01.
Posted 24 March 2014 - 17:08
Hi overlord,
glad that you've been able to solve your problem, and thanks fpr sharing the solution.
For completeness, addressing your original question: to look for the "office11" part of the string you might use:
OFFICE_VERSION ~>< "office11"
where >< means: left string contains right string, and ~ makes the comparison case insensitive.
(Note that this is probably not a robust way to dectect Office 11 if the user installed it in a custom location with a difefrent folder name)
