Hi I have a patch for my product when I apply the patch it works fine all the new files or patched files gets updated. But as when I uninstall the patch using command line as : msiexec.exe /uninstall [patch id] /package [product id] /L*V "C:\newpackage.log" /qb
it removes the newly added files and also reverts back some patched files (dlls) but not all the patched dlls. So my question is why all the patched dlls are not reverted back to the original files upon patch uninstall [note: dlls are versioned]. as because I can see some patched dlls are still the latest version and size not the original version.
To debug further when I looked into the baseline cache from windows\ installer\&PatchCache& . There I don't find all the original dlls those are patched . So I am bit confused how to investigate further
after uninstall of patch verbose log doesn't say any error : SELMGR command also not found.. logs says e.g one of the files that not getting reverted back ..
MSI (s) (1C:EC) [17:14:47:298]: File = some.DLL: Final State = Overwrite
MSI (s) (1C:EC) [17:14:50:059]: Component: QBDIR_some.DLL; Installed: Local; Request: Null; Action: Null; Client State: Local
MSI (s) (1C:EC) [17:14:51:201]: File = some.DLL: Final State = Overwrite
MSI (s) (1C:EC) [17:14:51:262]: The file represented by File table key 'some.DLL' has no eligible binary patches
MSI (s) (1C:EC) [17:14:51:262]: Chain for some.DLL starts with cached baseline file for 24.0.4004 (simulated sequence 0)
can anyone help me out here..
QBDIR_some.DLL is inside the feature ALLDLLS the log for this feature says
MSI (s) (1C:EC) [17:14:50:054]: Feature: ALLDLLS; Installed: Local; Request: Local; Action: Local which looks fine.
the other components which is inside the same above mentioned feature is getting reverted back. the log for the successful revert says as
MSI (s) (1C:EC) [17:14:50:059]: Component: QBDIR_utilities.DLL; Installed: Local; Request: Local; Action: Local; Client State: Local
MSI (s) (1C:EC) [17:14:51:201]: File = utilities.DLL: Final State = Overwrite
So here the diff I can find request and action . So why my QBDIR_some.DLL says Action is null . any idea??
Note: Attribute for the both components is 0 from component table.
Edited by preang, 04 August 2014 - 12:42.
