Hello everyone,
I have created a property "Front" to 0. Then,
i've created a condition of the installaton of a Component which will be installed only if the property "Front" =1.
If i modify the value by my own, the component is installed or not (if Front=0).
Now, i want to create a Custom Action which modify during the installation this value Front=0 to Front=1. (It will be the user who will decide if he wants this component or not).
To do that, i've created a CA as "Set a property" where :
-Property Name : Front
-Property Value : 1 (because it supposes to change 0 to 1 i guess)
Then, Synchrnous , Execut only once.
Sequence : Install UI Sequence After InstallWelcom
=> Doesnt work
I've tried as well to use VB
Session.Property("Front") = "1"
=> Doesnt work
I'm not realy used to using CA, that's why i need help
Thank you
Julien
